topic-stock injectors?
96 lumina 3100, how many lb/hr are the injectors rated for?
17 lbs/hr.Andy
fastest 1/8: 10.19@ 67.17
fastest 1/4: 16.16@ 82.70
The ECM would adjust the rich mixture to the correct 14.7:1 ratio until you go WOT, then it would run too rich and you'd lose power. I put the injectors out of a 3400 which are 19 lbs/hr. It runs great. If you need more gas you can increase the fuel pressure up to a point. You will still need to tune the ECM for that as well.Andy
