im looking for certain parts to really up the performance of my 96 3100 (lumina), if anyone can help me find any of the following i would REALLY appreciate it!
.60 or .80 oversize high comp pistons (the highest compression that i can run with 93 octane without problems).
peformance cam-pretty much anything, preferrably something that will up the power in the higher rpm range
intake setup- i intend to put a hoodscoop on it & run the intake to it, so at higher speeds the vehicle will get more air/cooler air.
ecm upgrade- some way to improve the power via the computer, & most imporantly to REMOVE THE SPEED LIMITER.
headers-anything that will fit in the stock location.
larger injectors or tb-anything that will up the hp this way (like 3400 tb & or injectors, whatever will allow me to get the MOST fuel flow that i can get).
o2 sensor emulator- i intend to run straight pipes with 2 high flow japper mufflers on the back, so i need something that will tell the computer that the o2 mixture is as good as it should be.
also, just as a curiousity, would 3400 or 3800 heads work, & if i could get all of these things, could the transmission handle it?
thanx guys
thanx guys
