POLL: Treulo vs Edelbrock intake
  • POLL: Treulo vs Edelbrock intake
    The poll is to find out which will give you the most bang for the buck between the two intake setups. Which to you will be better/cheaper for a turbo 3.4 ohv pushrod from the f-body setup and why? And no posting well i saw it run better in the 1/4 well that person could have spent alot of money on it to do so there is no way to tell if it was better just because he/she made a good run.
    1
    truelo
    100.00%
    1
    Edelbrock
    0.00%
    0
    You know that sun viser that doesn\'t quite go down when the sun is there and then when you are driving with it down and you can\'t see the stoplights ? Well... that\'s why my fiero isn\'t at the shop yet....
    Any injection system is more user friendly to a turbo.
    Slanted question.
      Yeah, carb and turbo are much more difficult to do vs fuel injection.
      You would have to do blow through carb or draw through.
      Blow through, you have to build a box for the carb and a fuel pressure riser hooked to boost to increase fuel pressure.
      Draw through, you end up using a large carb, so idle and off boost sucks.
      Curtis
      91\' Turbo Z24
      http://www.turboz24.com
