What ring gaps are you guys running?
  • What ring gaps are you guys running?
    Hey all, what ring gaps are you guys running?
    Stock max is .016" and .028"
    I'm thinking I'm going to run .026" and .030", since the last time I ran stock, I swelled the rings up enough to crack my piston...
    3.1L RWD iron head motor, running .020" oversized Clevite cast pistons...
    Would like some of your guys' thoughts
    3.1L \'88 Camaro - 16G @ 9.5psi
    222/291 @ wheels
    T61 on the way!
    update, discussed things with a couple people, now thinking more along the lines of:
    .022" top
    .026" bottom
    222/291 @ wheels
    T61 on the way!
      Not entirely sure since I don't have my line card yet, But I "think" the ring thickness is:
      1/16
      1/16
      3mm
      With a 3.642 bore
      Gas nitrated rings
      No info on the ring lands yet. When I get the details, I'll post 'em
      I'm taking Ross's recommendation for what they are going to provide. I was more concerned about accomodating the bore, which there are quite a few options at 92.5mm
      Perhaps this info is useless to ya at the moment...
      Regards,
      Todd E. Johnson
        So... Since I started another thread on this... lol. What did you end up with? And, what is your actual bore size?
        Regards,
        Todd E. Johnson
