Does anyone have any knowledge about how much the timing disc in the middle of the crankshaft on later model GM 60° V6s can be modified to reduce rotating mass? Info? Links? Anything?
It is a heavy little chunk o' metal and removing it (if practical) would add greatly to available power.
Thank you,
sg99
P.S. Yes, this assumes the replacement timing disc will be outside the engine, and much lighter as well.
Thank you,
sg99
