There was a technical bulletin for the GM trucks a few years ago that stated the cold start knock is actually due to carbon buildup on the pistons/valves. as the engine warms up the carbon is burned off and it sounds like a normal engine again. I've done fuel induction services on them and had the noise completely go away for up to 10,000 miles until they get dirty again. I know this is the bulliten for the GM V8's but i'd guess that the same thing might be happening to your car's engine. Before you try to run a thicker oil than recommended I would get your fuel system serviced or at least put a cleaner in the tank and see if your problem gets better or even goes away.
Now time for my off topic stuff: Besides eating less another reason Asians are thinner is because of green tea. Green tea is a popular drink in Asia and it's been proven to keep you thinner by raising your metabolism. It also has been proven to fight cancer as good as some new cancer drugs, and prevent it before it even starts. I used to eat fast food all the time and I had indegestion and acid reflux 24/7. 2 years ago I changed my diet and now include much more vitamins and minerals and less fats, I feel 100% better. Treat your body good and it will treat you good.
