I have a quote request into Ross right now. Work through a shop that has a relationship with a company (like Ross, JE, etc.) so you can get a halfway decent break on the cost... ( If they pass it on to you that is )
What companies make custom sized forged pistons for a 3400.
Originally posted by matt_p
You will have to get custom machined pistons made to spec.
Uh, that's what he was asking!??! Like Todd said, any piston manufacturer who does custom pistons will do custom pistons for this engine. There are many people out there who have had custom forged pistons made for these engines, so it is entirely possible. It almost sounds like your machinist is looking for an off-the-shelf forged piston, in which case there won't be any. Custom is the only way to go.
Wiseco made mine also, any CR. Specify rod pin diameter, or better yet send a pin. Piston, rings and pin were $130 each. They will make them to custom rod lengths also.
Mine will be .020 over as well, with a lower compression height, thicker rings, and able to accomodate .927 diameter pins with spirolox retainers. If that's not custom, I don't know what is
when i go to build my engine (im gonna use a 3400 block) i wanna go with an 8:1 c/r, the first ring about 0.250" under the crown (to give the ring land strength to hold up to extreme turbo abuse), gapless rings, taper walled pins and spiral locks
a few questions..... is it possible to do that with the ring on our engines? and about how much would you expect that to cost? what price range am i looking at? and also, whats a safe overbore when dealing with high boost levels?
