3.4L 94 camaro intake/head
  • 3.4L 94 camaro intake/head
    ok, I got a few questions. I've been doing searches but i can't find anything specific.
    1) What heads fit on the 94 3.4L Camaro engine? I'm looking to put some aluminum heads on my camaro. I've found a few 3.1 L heads on ebay, but I don't know if they're the same or not. What heads could I use, and which ones would be the best ones to use? I've heard late model grand am gt heads would work.
    2) Another problem with the camaro 3.4L is that it doesn't get enough air. Where can I get a good intake manifold?
    3) where can I get some general information about the 3.4L camaro engine? I don't know much about it - what gen it is, stuff like that. aight
    thanks for your help
    The 3.4 uses iron heads stock. Unfortunately, the aluminum heads and iron heads don't interchange easily. In order to use the aluminum heads, you would have to go with a FWD manifold combination as well. And since the CC of the aluminum heads is alot different than the iron heads, you would also have to go with a different set of pistons in order to lower the CR down to reasonable levels.
    But don't worry, there are a couple of guys on here that have done all of the above, so it is very possible to do.
    As far as info on the 3.4L, check out here.
    That sound at least give you an idea of where to start. Feel free to ask more questions as they come up.
      your homework is to read these threads to start
      The biggest dedicated V6 Camaro forum. Welcome to the Camarov6.com Chevy Camaro Forum. View forum tools. Join the V6 Camaro community. 6th Gen Camaro. 5th Gen Camaro. 4th Gen Camaro. 3rd Gen Camaro
      3.4L camaro some goodies
        if you have cash here are some bolt on solutions:
        When it's time to schedule maintenance or you need vehicle repair services, turn to the vehicle care experts at GM Certified Service. View available services today.
          http://www.gmgoodwrench.com/perfpart...299&section=ep
          LOL hardly. You can get all that in a junkyard. They are production components.
          Only 1 is a bolt on and he already has thoes iron heads.
            ooops, i didnt read that page i sent hahahaha.
            i just heard they made a performance heads and i thought those were them.
