Am I seeing things here?
  • Am I seeing things here?
    1.7 SBC rockers?
    World’s top manufacturer of performance camshafts, lifters, valve springs, rocker arms and related valve train parts for all race and street performance engines
    No indication if htey are narrow body though?
    call and ask??
      Note that they are for 55-87 SBC's.
      However, "INCREASED RATIO WITH STANDARD STUD DIAMETER, CLEARS 1.630" O.D. SPRINGS THE 1988-99 ENGINES EQUIPPED WITH SELF-ALIGNING ROCKER ARMS REQUIRE THE INSTALLATION OF PUSHROD GUIDEPLATES (AND 99157-16 ROCKER ARM STUDS, IF APPLICABLE) AND APPROPRIATE HEAT TREATED PUSHRODS IN ORDER FOR THESE ROCKER ARMS TO FUNCTION PROPERLY. VALVE COVER CLEARANCE MUST ALSO BE CHECKED IN LATE MODEL APPLICATIONS."
      Would have to have rocker arm trunion width's to know for sure. I'm assuming that they are talking about valve cover clearance due to the centerbolt v'covers' however it could be due to the 1.7 ratio
      Colin
        Summit says the body style is "Standard" so that would ean wide body. Narrow body is always specified on Summits site.
        Damn
          Does anyone know if the 3800 engine uses self alingining rockers?
          2000 Grand Am GT
          2011 Chevy Impala
            Sorry dont know. The old 3.8L however used regular SBC rockers. Dont know about the new ones though. I know someone makes 1.7 Rockers for the 3800 but I think they are a completly different size now.
              It apears they are self aligning. They sit on a guide bar much like GM's Vortec engines
                If the 3800 rockers would work in the 3400, ZZP sells comp pro magnum rockers in 1.6 & 1.8 ratio.
                2000 Grand Am GT
                2011 Chevy Impala
                  Rockers for the current 3800 are sold in 1.6, 1.7, 1.8, & 1.9:1 ratios.
                    no your not tripping
                    crane does have 1.7 ratio rockers for SBC applications
                    I Like V660s
                    Does Chevy make beer
                    ~Jayme~
                      yeah, but are they for centerbolt rocker covers though?
                      Andy
                      fastest 1/8: 10.19@ 67.17
                      fastest 1/4: 16.16@ 82.70
