3100 pistons would lower the compression due to the iron heads having a lager combustion chamber. now if you put the aluminum heads on a iron head motor you would have at least 11:1 compression!
14.96@91.47 in the 1/4
9.63@74.36 in the 1/8th
Nope...they have larger dishes, and would decrease CR considerably. This has been researched and discussed many times....there is no mixing and matching of off-the-shelf parts that will get you higher compression with the 3.1 iron head engines.
Marty
'99 Z-28 - Weekend Driver
'84 X-11 - Time and Money Pit
Quote of the week:
Originally posted by Aaron
