has anyone tired putting a 3900 intake on third gen 3x00 motor. the bolt pattern is the same as a 3500.
3900 inatke
Originally posted by sappyse107Does anyone here have a 3900 intake at all? Aren't they just now coming out?
What good would it do though without the hardware to control when the runners switch over plus tuning for the crossover. Gonna be more complicated than just bolting it on there.
workign the runners would be esay you could even hook up a vacuum switch to work a electroic control if you needed too. the 3900 have been out for about a year now, i have a buddy at GM that is going to be lookiong into it tommor at work to see just how the system works, let you knwo what i find out
The bolt pattern is the same as which 3500? I think I looked into the bolt pattern before and it is not the same as the 3100/3400/non-VVT 3500. Now yes, it is the same as the VVT-3500, but that won't do most of us any good.-Brad-
i have looked over a 3900 top to bottom and the intake will not fit the 3x00 motors without major mods. to start the manifold is only held on with 4 bolts but the lower manifold has larger ports and is overall longer than a 3x00 engine. oh well can't say we didn't try
if anyone wants to really give it a try i think they could make it work with an adapter plate.. gm part # 89018046. its like $236[SIGPIC]
12.268@117... 11's to come!
Originally posted by rx191to start the manifold is only held on with 4 bolts
I count 6 bolts for the Plenum on my car:
You would need the lower and upper together. I'm going to try and get the plenum off in the next few weeks just to take a look and some pics for those who want to know this stuff.Colin
what year car do you h.o. v6 i looked at an 06 G6 gtp and the inatke doesn't look quite like yours. i don't see any reason why that wouldn't work on the lower i have. i'm going to the la auto show on sunday i think i will be looking these engines over very closley.
Originally posted by rx191what year car do you h.o. v6 i looked at an 06 G6 gtp and the inatke doesn't look quite like yours. i don't see any reason why that wouldn't work on the lower i have. i'm going to the la auto show on sunday i think i will be looking these engines over very closley.
I was under the impression that the vanes were variable, meaning that it use PWM outputs from the PCM an stepper motors like the IAC, to control opening and closing.
