I own a 3.1 short block that came out of a 99-00 gm car, I am not to sure on the year. I have completely torn the engine down about a year ago and found that one of the rod bearing spun and the crank needs to be truned. The engine has roller cam & rockers. I believe it is a gen III but will be checking into it (the motor is at my parents house). I also dont have the intake or oil pan. Would it be possiable to use the lower intake off of my fiero 2.8 (I dont think I can but I had to ask), and if I found a lower intake for the engine can I use my injector's and fuel rail?
I would like to build the engine to handle ~15lbs of boost and am trying to put together a price list of things I will need to make this thing reliable.
I plan on porting the heads, intake, polishing the rods, making headders, and a stand alone engine mangement system.
This is what I have so far
Bearings rod & main $65
High pressure oil pump $80
ARP Head Stud set $220
3 angle vale job $125
Gaskets $75
Timing chain $40
Pistons $???
ARP main & rods $???
Shot peen the rods $???
Balance lower assm. $???
Head gasket (hold boost) $???
LS-1 valve springs $???
I know I forgot stuff so feel free to add anything. Links to sights that have the parts would be nice also, I got most of the prices form summit and rock auto.
Thanks for your help
Marq
Gaskets $75
Timing chain $40
Pistons $???
Marq
