Does anyone make higher rate valve springs that will fit on the 3x00 heads with no other modifications? I know this is probably a question that is already asked. Will 3x00 heads be available on the 60 degree store any time soon?
Valve Springs
Yes, heads will be available soon. Actually I can take orders now for them but I havent redone the new store or figured out how to advertise them. If you are interested in having some done right away or soon, PM me with what your application and goals with the motor and I can tell you what I can do.
I would like to see what the comp cams springs will do, as they should be stiffer and also ovate spring which allows for more lift before coil bind.Ben
