Can an alternator be run CCWise as well as CWise? If yes, do electrical changes need to be made? What changes? Are there any electrical or mechanical problems to consider?
Alternator drives
Originally posted by The_RavenThe problem with running them backwards is the fan is not set up for reverse rotation and will need to be changed with one that is, expensive to do.1993 EXT. CAB, 3.4L V6 TBI, 5spd manual. Sonoma
Originally posted by betterthanyouOriginally posted by The_RavenThe problem with running them backwards is the fan is not set up for reverse rotation and will need to be changed with one that is, expensive to do.
(Most) Honda engines spin in reverse though. But use small ass alternators.
Also the Twin engine boats, not all use a reverse rotation for one engine, and besides, any that have, that I have seen use one alternator to feed both engines.
