All you guys are installing your LS1/LS6 springs at a shorter install height than the spring is spec'd at. No big deal really. But if you are looking for a few more thou valve lift and/or an alternative retainer then check out this one from Comp. It is designed to be used when installing LSx springs on and LT1 or Vortec head.
Stock LSx retainer on the right.
![](http://members.shaw.ca/betterthanyoutoo/retainer1.jpg)
![](http://members.shaw.ca/betterthanyoutoo/retainer3.jpg)
Also for an alternative spring, Comp has this one which is stiffer than an LS6/LS2 spring. Good for a longer duration and higher lift cam such as a Milzy Stange 1 (maybe stage 2) or a comp 260 or 272 cam (for hybrid guys)
Stock LS2/LS6 spring on left
![](http://members.shaw.ca/betterthanyoutoo/lsspring1.jpg)
![](http://members.shaw.ca/betterthanyoutoo/lsspring2.jpg)
