I found GM part number for a set for a 3400 but I'm wondering if there's a p/n for a set for a 3100 as well. The reason for wanting graphite is for moderate boost (~10psi) after a ported/polished top-end swap with a 3400. I was told to use the 3400 gaskets but that didn't seem right to me. Thanks in advance if you guys can point me in the right direction.
3100 Graphite Headgaskets?
Re: 3100 Graphite Headgaskets?
Originally posted by AzraelI found GM part number for a set for a 3400 but I'm wondering if there's a p/n for a set for a 3100 as well. The reason for wanting graphite is for moderate boost (~10psi) after a ported/polished top-end swap with a 3400. I was told to use the 3400 gaskets but that didn't seem right to me. Thanks in advance if you guys can point me in the right direction.
Don't graphite gaskets hold up better to deterioration due to "hot spots"? Of course, this is just my limited knowledge via google, and noticing they are used with a lot of forced induction setups (other than copper).
I had been using the older 3400 head gaskets from a rebuild ~3 years ago. They were holding up, however, they were starting to somewhat bubble up around the coolant passages on the block where there is no corresponding passage on the heads....
Originally posted by AzraelSorry. It's a 95 3100 block with 96+ 3400 heads.
what is the part # for the 3400 graphite head gaskets? while where on the subject2002 Pontiac GrandAm GT1
3400 v6
TOG headers
RSM 62MM T-body
FFP underdrive pulley
GRANATELLI MAF
Ported upper intake
MSD DIS 4 ignition box
MSD Wires and coils (pending)
Venom high flow fuel pump (pending)
Originally posted by AzraelGM 3400 Graphite Headgasket: part # 12577403
See:
Old: http://groomlakelabs.com/gallery/phase_three/IMG_2599
Old: http://groomlakelabs.com/gallery/phase_three/IMG_2600
New: http://groomlakelabs.com/gallery/phase_three/IMG_2604
