Lightweight Starters?
  • Lightweight Starters?
    RWD applications use an old tech heavy starter while the transverse engines use a smaller lighter and supposedly more powerful starter.
    Unfortunately not interchangeable as they bolt on opposite sides of the block.
    Anyone know of a RWD substitute starter in the FWD style?
    okay maybe I'll just sound like a moron.. but won't an SBC lightweight race starter work for 60 degree v6s ... FWD or RWD if you buy the ones with the adjustanble solenoid offset?
      That's exactly what I am wondering.
      Maybe the same as the 90 deg. V6 as well?
        u know the funny thing about this q? yesterday at work (autozone) some1 purchased a new starter for their 01 GAGT, and it was made wrong, it looked like it would mount on the other side of the block, perfect for RWD LOL.
        [SIGPIC]
        12.268@117... 11's to come!
        [url]http://www.youtube.com/watch?v=7ibU1k8UZoo[/url]
        [url]http://www.youtube.com/watch?v=GUqJyopd720[/url]
          i believe their called gear reduction high torque starters, but people were saying they don't have them on the newer 660's there just different from the older ones
          [SIGPIC][/SIGPIC]
            I spent the time going through the catalogues and comparing starters.
            There is a lightweight high torque starter used in some of the vans and even on the 454 trucks that should sub for the Camaro - half the weight and it will spin a big block - what's not to like?
              Did you check the 3800 camaro's and see if the starter is on the correct side, like the 3.4 camaro one?
              Curtis
              91\' Turbo Z24
              [url]http://www.turboz24.com[/url]
                All the 660 RWD starters are big. My donor 3.4L came from a 95 which was the last year for RWD and it was identical to my S-10
                Because... I am, [COLOR=darkblue]C[/COLOR][COLOR=darkred]A[/COLOR][COLOR=darkblue]N[/COLOR][COLOR=darkred]A[/COLOR][COLOR=darkblue]D[/COLOR][COLOR=darkred]I[/COLOR][COLOR=darkblue]A[/COLOR][COLOR=darkred]N[/COLOR]
                  Yes, but there are other later starters that are not big and that do fit the 3.4.
                    Right, but not off a RWD 60*V6
                      Yes, that's what I meant when I said 'other' starters.
                      They were used on 90 deg. V6 and V8 applications but fit V6-60
                        Indeed. One thing I do know is that the bolt holes on SBC starters are SAE and 660 ones are metric and slightly larger. So you will have to drill out the holes a tiny bit.
