Thought this may interest some of you:
Any thoughts?
Todd, as far as I know there are two types of V6 engine.
V6 Semi Even flat tappet 200-229 cu.inch, which would be p/n CS1000.
V6 Even Fire Flat Tappet 262 cu.inch, which would be p/n CS1000 again.
V6 Even Fire hydraulic roller cam followers Factory that would be p/n CS1020.
From my understanding, these are exactly the same timing sets used in the V8?s
The last number is a TPI timing set that has a thrust plate and reduced nose on the camshaft and a smaller register on the cam sprocket.
Go to my web site listed for more options.
Secondly, while there click onto my US Distributors button and call one of them for service.
Best regards,
Robert (Bob) Brackam,
Proud Manufacturers of:
Rollmaster Timing Chain Sets.
Romac SFI Approved Harmonic Balancers & Driveline Components.
Precision Cam Drives P/L & Romac Performance Products
21 Spine Street Sumner Park Queensland Australia 4074
Web: www.romac.com.au
-----Original Message-----
Sent: Thursday, November 17, 2005 1:43 PM
To: bob@(removed)
Subject: Timing set for Chevy 60° V6
Hello,
I am curious if you have anything for the Chevy 60° V6 engine. The 2.8,
3.1, 3.4, 3100, & 3400 all have the same centerlines. I am aware that
Cloyes sells a double rocker timing set, and it would fit, however, it
is for the 2.8 & 3.1 engines, which is a higher profile. I was told of
a company in Australia whom makes a lower profile double roller timing
set. Would you happen to be that company? If not, do you offer
anything at all for these engines? Thanks in advance!
Regards,
Todd E. Johnson
Best regards,
To: bob@(removed)
Hello,
Regards,
Todd E. Johnson
