Cam specs
  • Cam specs
    i'm trying to figure out what cam is in my 94 Z24 3.1. i've been told it's the same as the turbo GP. which is 196/202, .395/.410 LSA109, i've also been told it's 184/194, .365/.395 LSA 109. which is correct if either? thanks
    Andy
    fastest 1/8: 10.19@ 67.17
    fastest 1/4: 16.16@ 82.70
    i have heard sotries of the cams being the same and not, theres alot of mysteries of the tgp engine
      then what the hell do i have? it'd be nice to know, but really dosen't matter.
      Andy
        Pop the V-cover and slap a dial indicator on the pushrod
        At least you will know the lift
          good idea. it's a start, but still won't know duration for sure. man, why is it so tough? same with torque capacity for the 125C. can't find info for that either.
          Andy
            If you have a degree wheel you can measure duration with the cam in the engine. However with the FWD configuration it will be hard to read the wheel.
            When measuring the lift be sure to pop the rocker off so the lifter plunger is not pushing against spring pressure and collapsing.
              thanks for the info, but i won't be taking anything apart until i rebuild. and by then, i should have info by then. if not, oh well. i'm more just curious as to what the stock is and how much bigger i'm going over stock.
              Andy
                what cam did you finally decide to go with?
                  the 272 baby!! i want that lopy idle!
                  Andy
                    good choice i think i know someone else with that cam
                      yeah, i just talked to another guy and he knows a couple of other people that have em. he said it'll step off with authority and keep climbing up to about 6300. that sounds great to me! i just wonder if i'll have more low end than the stock set up.
                      Andy
                        I have a custom grind cam with similar specs to the 272, but more directed for a turbo setup, and my bottom end is uglyness, really bad until 2500 when the turbo kicks in. However, it can pull to 6500 no problem.
                        Brian Edwards
                        '73 Trans-Am
                        '79 Suburban
                        '90 Beretta INDY
                        '90 Turbo Grand Prix
                        '04 TSX
                        '04 TL
                          z284pwr, you know what your LSA is?
                          Andy
                            i wouldn't mind sacrificing bottom end power, since traction is going to be an issue with boost
                              Yeah, its 115*
                              Here is the card
                              I wish I had the Seat to Seat timing to so I could put it in Dyno 2003 for the cam ramp rate
                              Brian Edwards
                              '73 Trans-Am
                              '79 Suburban
                              '90 Beretta INDY
                              '04 TSX
                              '04 TL
