Can anyone guess?
  • #31
    wow looking good!
    14.96@91.47 in the 1/4
    9.63@74.36 in the 1/8th
    • #32
      Originally posted by blackbombshell95
      is their a reason why people just don't drill holes in the plenum?
      yeah i was going to hide everything under the plenum originally, but there is no room for the piping.
      this way its also easier to change jet sizes. i suppose you could put them right on the UIM but if i ever wanted to get rid of the unit it would be an easy bolt in for anyone else with large port runners, with only things needed being 60mm bolts and another gasket.
      more then that though, i didnt like the angle that the nozzles would have had to sit, to get the right spray angle, if they were in the uim.
      got zap-straps?
      89 Z24
      13.886 @ 96.16 mph
      street trim - slicks
      • #33
        those parts polished or chromed? pretty!!!!
        Andy
        fastest 1/8: 10.19@ 67.17
        fastest 1/4: 16.16@ 82.70
        • #34
          polished aluminum
          did you consider using "NOSzles"?
          • #35
            thoes header flanges sure look good. where did you get those from?
            • #36
              if you havent got the holes aligned or some1 wants a one off set, if you have a big enight scanner you could scan the upper plenum on the scanner to get exact measurments. just a thought, those are sweet thought man i wouldn't mind a set, nice job!!
              • #37
                They were designed from a CMM of the actual lower manifold, so they will be alot more accurate than trying to go from a scanner.
