Milzy cam specs
  • Milzy cam specs
    for all of those out there who wants a cam, but wont buy the milzy one due to lack of specs, here are the specs directly sent to me my Mike "Milzy" Miller. these specs are for the 3x00 cams
    Stage 1 NA - .305/.308 lobe lift (.488/.493 valvelift),
    209.4/213.1 duration,
    110 LSA, 108.1 IC
    Stage 2 NA - .347/.349 lobe lift (.556/.559 valvelift),
    222.1/225.7 duration,
    110 LSA, 106 IC
    94 Grand Prix
    RE: Milzy cam specs
    Cammotion will do any specs you want. I lost their email due to my laptop hard drive dying, but will get their phone number again hopefully. I plan to get some cams made for my ported products as well. I will also be looking to the members on this board for their input on specs they would like to see.
      Yeah, Cammotion still sell them for 380$
      I am eyeing up this grind for my S/C setup :
      RECOMMENDATION
      Grind Number X2161-2222-14+4
      Duration (intake/exaust) 214/224
      Lift (intake/exaust) .531/.540
      Lobe Center Separation 114
      Intake Centerline 110
      Comments
      Price US$380.00 + SHIPPING
      Thats what they recommended when I filled out their cam sheet.... Too much lift for my new stock LS-2 valve springs though...
        Superior high performance LS & Gen 5 LT camshafts for GM cars and trucks equipped with LS1, LS2, LS3, L99 & new LT engines.
        1995 Monte Carlo LS
        3400 SFI 60v6
          Awesome Nice to see all their grinds on there too, should make it easy to order the cam you want.
            if you register on thier site you can fill out thier form electronicaly and they will give you a reccomended spec for your application
            AFAIK MMS cams are actually Cammotion grinds
            1995 Monte Carlo LS
            3400 SFI 60v6
              Yes they are, as cammotion is the only one with the blanks for the 3x00 motors right now. I will have plenty of specs to give them
                do the specs for the milzy cams seem decent? i thought they were, seem to be a bit radical, if im thinkin right.
                i would rather go with a cam that sappy supports.
                the duration numbers given from milzy is not avdvanced duration, correct? the numbers seem to small to be that. but the stage 1 cam should be around the 270-280 for the advance duration, correct?
                thanks
                94 Grand Prix
                  You mean advertised duration. And no they are duration at .050 lift.
                  I like the specs but I think the LSA should be around 112*
                    yeah thats what i meant, i havent dealt much with performance cams, im still learning, usually for me its just buy the one from jegs that souds like it fits my rpm range best, for the v-8s. but thanks
                    94 Grand Prix
                      just one question, the duration seems a bit much on both compared to the stock cam right? also what is LSA? and IC?
                      on the Cam toppic on here the regrinds they talk about are both considered radical. why is the stage 1 not consitered so radical?
                      thanks for the grate topic!
                      2002 Pontiac GrandAm GT1
                      3400 v6
                      TOG headers
                      RSM 62MM T-body
                      FFP underdrive pulley
                      GRANATELLI MAF
                      Ported upper intake
                      MSD DIS 4 ignition box
                      MSD Wires and coils (pending)
                      Venom high flow fuel pump (pending)
                        Isn't stock LSA 112* ?
                        If so then why not get a regrind to those specs and save some $
                        2000 Grand Am GT
                        2011 Chevy Impala
                          LSA - Lobe Seperation Angle : Angle between the peak of the intake lobe and peak of the exhaust lobe. Determines how much overlap you will have between the opening of the exhaust and closing of the intake. Wider LSA, less overlap and vice versa.
                          IC - I can't find my cam card online, but I'm pretty sure it has to do with the intake centerline of the cam on installation.
                            While I appreciate the confidence, I am really not the person to be asking what cam specs are best for an application. Other members on this site are better educated in that department than myself as are the cam manufacturers.
                            The head can probably be machined to allow the higher lift and make more use of the LS motor installed heights vs what our motors use stock. Not sure how great the pressure would be closed though but thats something to look into if other springs aren't easily obtained.
                              I seem to remember seeing the 3400 stock LSA at 114°. Makes some sense since the 3400 torque curve is fairly flat.
                              1991 Cavalier VL Coupe 3400 5 speed
