N00b question... How fast could this spin...and work?
  • #46
    k, my acadian has had a couple trips to 8500+ w/o a healty oilpump.. so without doubt I had a rod knock after.. so i babyed it for like a month.. and just this past weekend I took it out for a last run with my buddy folowing me in his truck.. and I went straight to the highway.. i held it in 3rd gear.(373 gears) at some 150kph.. it was reving in the means of aboot 9500+ untill the rev limiter that is built into my ingitin system kicked in.. the point of the story is.. i held it like that for about 2miles before it finaly gave way an ended by a snap and a rod threw the side of the block.. so if you can do that with a shitty old 2.8L with a screwed rod.. it is clearly... Possibale with a ballenced engine.. ( by the way juss to let yall know how much of a trooper the little 2.8L was it started for a second even after the rod went clearly threw the block...)
    Six-t-Six Motorsports
    2.8L Chevette Roadcar
    3.2L Acadian Racecar
    • #47
      Ohh ya and my whole incodent that i did there is video to prove it.. so if i could put it somewere on the net yall'd be able to see it
      • #48
        What cam is in that thing? How was it even possible to keep going higher and higher?
