Is it really worh the trouble to get rid of the EGR? Any performance gains? My repair manual (hains) says it actually helps keep the engine cool at times. Looks like a real pain to get the custum chip for it, then make block off plates on the intake and the exhaudt manifolds. Thanks for the input. Car is a '95 GA SE.
Egr delete.
No real "gain" by getting rid of it. I only removed mine because I did not want to put another "bung" on my downpipe...
All you need is a small piece of aluminum with a couple holes for bolts on the manifold. Then a parst store should have a block off fitting for the exhaust manifold.1993 EXT. CAB, 3.4L V6 TBI, 5spd manual. Sonoma
CNC what? Dude get a flat piece of 1/4" aluminum cut it the outside shape of the gasket with the holes. Put the gasket on and bolt it down. Done no leaks.1993 EXT. CAB, 3.4L V6 TBI, 5spd manual. Sonoma
If I watch how I drive, I can get the light to not turn on. The only time it turns on is if I coast from a high rate of speed for alittle while without tapping the pedal or being hard on the brakes.-Brad-
Originally posted by RednBlackCutlassMy unit is still there, but the PCM part has been neutered.No loss, no gain. The unit shall soon disappear. It's ugly anyway.
Funny, but informative.'91 Cutlass Supreme sedan - 3.1 Intercooled Turbo / Getrag HM-282 5-speed - 13psi / lightly modded
'98 Regal GS - 3800 Series II Supercharged/HM-4T65E-HD - 180* T-stat, otherwise stock
GM W-body Forums
Mine's gone. Only reason I got rid of it really was it was really hard to install and remove. Between aftermarket headers and the supercharger, it made working on anything a PITA since I always had to disconnet it, plus it took up a lot of room in the back of the engine bay with the tubing and adapter to route it to the SC. Really cleaned things up by taking it out, and eliminated a source of heat going into the blower.
I just used a flat aluminum bar with a couple holes drilled in it and the stock gasket to seal the intake mani. Header bung I used a brass pipe plug and some copper RTV and that sealed it right up. For the computer I have a DHP powrtuner so I just turned off all the EGR codes and set the activation point so high it would never turn on. That basically eliminates it from the equation.'97 Grand Prix GT 3800 (sold)
Gotta love boost!
