I had built a 3.4 in the past and got good times out of it (mid 13s). The problem I had with the engine was that the stock head gaskets would only last a couple passes on a 100 shot. It had ARP studs and unfortunately cast heads. The block and head surfaces were resurfaced a couple times to ensure that they were straight. Here are my related questions:
Does anyone make a stronger aftermarket head gasket for the 60 degree engines?
Is the deck thickness of the aluminum 3x00 heads thicker than the deck thickness of the cast heads? And then, would they be stronger?
Thanks,
Jim
Thanks,
Jim
