Originally posted by RacerX11
Header flanges? (Now ready for Sale!!!)
I just measured the exhaust ports on my 3100. A properly centered 1.5in hole would fit over the port just fine. If centered around the port, there would be about a .25in overlap. Just thought i'd let you know. It might be better to make them 1.5in instead of 1.625in. That way you can use either size tubing.
-Joseph
Originally posted by FallenZ24I just measured the exhaust ports on my 3100. A properly centered 1.5in hole would fit over the port just fine.
Brad, did you draw up any ports with 1-1/2" ID pipe?
Marty'99 Z-28 - Weekend Driver
'84 X-11 - Time and Money Pit
Quote of the week:Originally posted by AaronThis is why I don't build crappy headers. I'm not sure, I don't know too much about welding.
No they were D shaped. I think it should be revised to use a 1 5/8" OD tubing. Then you can put the tubing inside the hole in the header fange and use a fillet weld to seal it up.
Whe Brad revises it I will cut them.1993 EXT. CAB, 3.4L V6 TBI, 5spd manual. Sonoma
I used 1.5" tubing for mine, and have seen no issues. I actually had to stretch the 1.5" slightly to meet with the corners of the D.
Ok, I'm going to ask now, before any more happens.....
Are the port openings going to be round or D-shaped?The reason I ask is because if they are going to be round, I'm out. I want/need the D-shape in them.
The current way they are drawn is with a 1 5/8" OD D-shaped port.-Brad-
Originally posted by betterthanyouOriginally posted by RacerX11Originally posted by FallenZ24The verticle spacing for the bolts are different on the older generations unfortunately. I found this out the hard way...
I was unaware of this. I was lead to believe that the spacing was the same. Well, screw the genII. Everybody know its dieing out. :P
-Jospeh
GenI and II share port spacing
The circumference of the port is within a couple thousandths of the circumference of a 1 5/8" tube. I'm sure the tolerances of the laser won't be that close though... Obviously, the tube will have to be formed to fit the port.-Brad-
Originally posted by The_RavenOriginally posted by betterthanyouOriginally posted by RacerX11Originally posted by FallenZ24Originally posted by tejohnsonThe verticle spacing for the bolts are different on the older generations unfortunately. I found this out the hard way...
-Jospeh
The specs for the flanges sound good. What type of time frame are we to expect before these are ready for sale? I'd like to start my headers soon and the flanges are the main thing holding me up.
-Joseph
It would be best if the flange opening is a little bigger than the exhaust. Round hole preferred really as most of the flow is coming off the top rounded part anyway, not the bottom. I havent measured a port yet but there is no reason to make the flanges D shaped.Ben
im also interested in a set. let me know as soon as your done.[SIGPIC]
12.268@117... 11's to come!
Originally posted by sappyse107It would be best if the flange opening is a little bigger than the exhaust. Round hole preferred really as most of the flow is coming off the top rounded part anyway, not the bottom. I havent measured a port yet but there is no reason to make the flanges D shaped.
This coming from a guy that is keen on port matching.
