What ecu would i use for a heavily modified 3x00? or what can i have done to maximize the engines potential?
What ECU
RE: What ECU
A standalone...-Brad-
Why does everyone always bring up the TEC3?
Although the TEC3 is an outstanding standalone, there are so many others out there from Haltech, F.A.S.T., SDSEFI, Perfect Power, etc...-Brad-
You might want to look into the Megasquirt.
I'd go with a Haltech. Depending on the year of the car though, you might wanna stick with the SFI ECU and a little DHP action.97 Cavalier RS
3400, Isuzu MK7
From what I understand, from the guys at work that have them, is that MegaSquirt can't control an electronic automatic transmission. If you have a manual (swapped, of course, none offered from GM), then it's not an issue. DHP and the tuning/flashing software that they offer is probably going to be your best bet in this case. It's what I'll be using to get mine tuned next spring to get the fuel trims right, and see how far I can advance timing without knock, and just gain info on boost, and that sort of thing.\"NASCAR is an integral part of my life. A part of me died when Dale Earnhardt died.\"
if you need something to control the automatic transmition there is a company called powertrain control soultions that has a trans controller that is fully programmable and they can preprogram it for your trans. You can modify the shift points and so on with a laptop. It also has the ability to use manual auto mode with steering wheel paddles if you want.95 Beretta Z-26
