Pics of the crank/cam sensors in the engine?
  • Pics of the crank/cam sensors in the engine?
    Anyone have any pics of the cam/crank sensors, in the 3.4 RWD engines? I'm curious as to how GM did that....
    3.1L \'88 Camaro - 16G @ 9.5psi
    222/291 @ wheels
    T61 on the way!
    RE: Pics of the crank/cam sensors in the engine?
    What is it that you want a picture of? The locations? or the sensor themselves?
    The OEM crank trigger was mounted low on the right (passenger) side of the block, between cyls #5 and #3. You would need to use a crank with the 7x reluctor ring to use this location.
    The Cam sensor is mounted in a bored hole at the front of the engine, where the intake mating surface is between the head mating surfaces. You would need a cam with a Sync t use the same idea.
      I have the sensors in my stash somewhere. I can take pics if you want.
        I'm trying to find pics of the sensors on the block, and where they bolt to the block itself...
        222/291 @ wheels
        T61 on the way!
          If I only had a digi cam....
            I could get pics of the block location too. I have freeze plugs in the holes
              Yeah, scratch that guys... I don't think the 2.8/3.1 block has the appropriate spot for the crank sensor in the block itself
              222/291 @ wheels
              T61 on the way!
                No it doesn't, this is why I made an external crank trigger for my hybrid.
                The 2.8/3.1 blocks also do not have a spot for the cam sensor either.
