Anyone running a solid cam?
  • #31
    Yeah, the later blocks are MUCH better than the early ones.
    The reason for a larger intake vs exhaust duration is because like 80% of the turbo setups out there on the street are designed for very quick boost - LOTS of backpressure. I went the other way, and built this as a low backpressure, high rpm beast. So I can get away with more exhaust vs intake duration.
    Always remember, look at your engine as a SYSTEM, and make sure all parts complement each other!
    3.1L \'88 Camaro - 16G @ 9.5psi
    222/291 @ wheels
    T61 on the way!
    • #32
      doward, sorry for hijacking your thread. I agree the later blocks are better but I would rather machine my early block because its got the very nice exhaust that wraps UNDER the engine and sadly the oil pan wont interchange with with later blocks. Having the exhaust going under the engine equals more power and will allow me to run a custom true dual exhaust w/ sidepipes. I am not planning on using a turbo (its not in the "period" of style I want) so thats not an issue. Basicly, I want to build a high RPM NA motor. The 2.8 is a basic grunt motor that has great low end torque and so I want to enhance the top end and a solid cam sounds like a relatively easy way to do it.
      Tuning a car is full of compromises. You must decide if you are willing to give up either reliability, performance, or a whole load of cash. Also remember that repairs will seem to come up much more often as you strive for even more performance
      • #33
        this is what happend when I spun a rod bearing on my 2.8 and tryed to make it home! it was the orginal block in my 83 firbird!
        14.96@91.47 in the 1/4
        9.63@74.36 in the 1/8th
        • #34
          Hey, Curtis - any problems with knock sensor going mad with teh solid cam? Also, what lash are you running, if you don't mind me asking?
          222/291 @ wheels
          T61 on the way!
          • #35
            Lash is .022" and .020". I don't have a knock with the haltech (you just program it correctly), so no issues with that.
            Now if only the tranny would survive...... Blew out another one.
            Curtis
            91\' Turbo Z24
            http://www.turboz24.com
            • #36
              Ouch, that always sucks. At least I always have the option of a T56
              222/291 @ wheels
              T61 on the way!
              • #37
                That Crower 03065 cam mentioned in the first few posts seems weak. the lift is barely better than stock. i went with a the comp cams 260 in my 3.1. powerband is 1k-5k. The lift is .440 in/out. I plan on 1.52 rollers but if you add 1.6 rollers you get .470 lift.
                Clean Feet Pet Clean Up
                Pet Waste Removal Omaha
                We offer dog waste removal and cat waste removal services.
                (402) 320-3824, We service the Omaha, Ne. metropolitan area.
