HP difference in raising compression
  • HP difference in raising compression
    How much HP might i get out of raising the compression on a modded 3400. CAM P&P headers/dp/catback/forged pistons. lets say from stock to 10:1 or 11:1?
    how much tuning would be required if i were to raise my compression?
    02 GTP - 90* > Failboat
    www.blackbombshell95.com
    RE: HP difference in raising compression
    What computer are you going to use for tuning? You can go 12:1 and run pump gas no problem as long as you have a matching cam regrind. Been done, ive tuned it
      cool. When I pull my 3100 out next week, i'm placing a chair in the bay and having a friend convert my obd 1.5 to 1.0!! and in goes the 3400.
      what kind of hp should I expect from going to 12:1?
      and as for a matching cam regrind? How should the cam profile change in relation to the compression?
        for a full point of compression change such as your questioned change 10:1- 11:1 you would see roughly 4% power difference. on a 200 HP motor that would be about 8 HP + or -
        Colin
          Remember...
          that's 4% after any other mods.
            RE: Remember...
            xoneith has milzy setup with .015 of the head and he thinks his comp is around 10.1:1 making 200WHP
            Donesic Disurbance
            Grand Am 3400
