Im building a 2.8 with heads from a 95 beretta non roller cam motor, and am looking for the best rockers, lightweight, full roller, and high ratio. The intake manifold, valve covers, and cam lift dont matter in this application, they can be made to work around the rockers.
So what enignes have rockers that will bolt on to a 3.1?
The valve covers will be made as high as nessecary, the intake manifold will have shorter runners on it that turn upearlier so that I can mount the carbs right in the center, thus no interfierence with the rockers, and the cam will be a custom grind, so the higher ratio rockers will allow me to run a lower lift cam and a less agressive ramp for the same result.
If anyone happens to know of some aftermarket roller lifters, or an engine that used lifters that will fit the 2.8 block,even if a bit of boring is required, that would also be very helpful.
thankyou
MAtt
thankyou
MAtt
