I have an '88 fiero with a 2.8. I would like to swap the timing cover and accessories from a fwd 2.8/3.1 onto my fiero engine. I think I would derive the following benefits:
1] More clearnce at front of engine.
2] I could use the V-5 compressor instead of the DA-6
3] It is a full serpentine setup. The Fiero's current setup requires me to constantly tension the belts.
I realize I would have to work something out cocerning alternator placement
So I guess this boils down to:
4] Will the new timing cover bolt up?
5] Can I exchange the Fiero's balancer and crank pulley for the 3.1's
6] Will the bracket that holds the rear of the V-5 compressor to the block, bolt to the fiero's block?
