Better radiators
  • Better radiators
    For my 1997 Cutty, where can I find a heavier duty radiator? Working towards a 280HP goal, better cooling is needed. Thanks.
    RE: Better radiators
    Are there any in Summit that you could make work for you? I would try to make something off the shelf work, but you could always have someone do a custom one if you wanted to pay for it.
      Griffin Thermal Products Radiator Manufacturer, Aluminum Radiator, Custom Radiators, Heavy Duty Rad, Performance, Off Road, Industrial, Muscle Car, Street Rod, Radiator
      hi cfm fans
      not sure if they have anything that is marketed for your car, but im sure if you talked to the guy and gave him your measurments hed have one that fits...
      or you could call alocal rad shop and get a 3 core rad
        I suppose, I hadn't even thought of just using dimensions to find one. Duh! Thanks for that help.
          www.howeracing.com had one that fit my Cav perfectly and not too expensive either.
          Curtis
          91\' Turbo Z24
          http://www.turboz24.com
            Thanks for the link. I'll look in to it.
              Did you check to see if the '97 GTP's had a better radiator than your 3100? I'm not sure if different W-bodies shared the same rdiator shapes or not, but the GTP was 245HP stock, so the radiator should have enough cooling capacity to handle 280, and would be an easier fit than a custom aftermarket rad. You might also just wait until you get the engine built and see if you need the extra cooling capacity. No sense spending the extra money if it isn't necessary.
              Marty
              '99 Z-28 - Weekend Driver
              '84 X-11 - Time and Money Pit
              Quote of the week:
              Originally posted by Aaron
                I hadn't even thought of that. Thanks for that idea, too. See, you guys always come up with something!
                  OK, talked to a radiator shop in the town where I work, and he came up with a 1-1/8" core unit, apparently from a '92 CS with a 3.4 DOHC. It, of course, isn't a factory unit, but would that even fit my '97? The stocker is a 5/8", he told me, to that's twice the thickness. Thanks.
