Well I'm considering replacing the stock carb on my 81 Skylark Convertible.
However being new to this type of mod (I usually just a stock kind of guy) I'm in need of some help. I'm considering doing this upgrade now as the mixture control solenoid is bad and I can't see spending $100 to get a new one. It would seem to me that it would be better to spend $100 in some upgrades.
Here seem to be the most popular carb choices
Holley 4160 390cfm
Holley 5200 350 cfm
Weber dual 38
Now can I bolt these to my existing intake or do I need to an Edelbrock Torker II or Offenhauser manifold intake as well?
I'm going upgrade the heads with the H.O ones from from an X-11, they'll get ported and polished (winter 05/06), and eventually get a CAM, Headers, Exhaust. But these are all further out projects, I'll need the Carb to work with stock stuff this summer.
Does replacing the carb mean that I'll need to redo the ignition as well since I'll strip out a lot of ECM connections? If so how is this done?
Thanks,
Will
Holley 4160 390cfm
Holley 5200 350 cfm
Weber dual 38
Thanks,
Will
