Ok so I have my 3.1L MPFI motor broken down and I was wondering what all I should have done to the motor when I have it sent to the machine shop. I plan on putting a 3400 top end on the motor and eventually some boost. Some of the upgrades I been considering are new hypereutectic skirt coated pistons(CR I should shoot for?), double roller timing chain, clevite mains and rod bearings, chrome ring set, and fel-pro head gasket set.
So basically what services should I have done to the block while at the shop so that the engine will handle boost, and still be a reliable daily driver. I was considering having the block bored, but not sure if it would hurt cylinder strength with the extra pressure and even be that beneficial. Lastly would it be advisable to use ARP con rod bolts, mains studs, and head studs(I did find the head stud lengths in the performance section but will this work all right with a hybrid?)over stock hardware and what part numbers are these since there isn't a specific kit for the aluminum head engines other then the iron heads. Thank you for looking and your time is appreciated.
