95 was a tricky year. Going into ODBII I guess. I'm not sure if it MAP or MAF. If it is MAP then that would be cool since I can put that supercharger on it like I wanted to.
I'm just not sure hybrid....
Every GM car has a MAP sensor. Even if it also has a MAF sensor. Something is required to read vacuum.
Most cars from other companies also have a MAP sensor of some kind even if they are MAF equipped. Some do not have a MAP sensor but only a few.1993 EXT. CAB, 3.4L V6 TBI, 5spd manual. Sonoma
I agree with Cliff on the A-bodies. You can look at the pinouts/wiring diagrams on the site and see there is no MAP input into the PCM.-Brad-
