How much advance is best? for the 2.8
  • How much advance is best? for the 2.8
    I am running a 2.8 overbored .050 with a Holley2300/Edelbrock carb setup and a vacuum advance distributor. The distributor was re-curved by the speed shop to advance 26* and give it 36* overall advance WOT when initial advance is set at 10*.
    This is engine is punched out, ported, polished, GM HO cam, with a 2.5" exhaust.
    I've been trying 0*, 10*, 11* and even 12*. I can't figure out the best setting. With full, ungated vacuum at 10* initial advance, it will give me the 36* WOT but more like 16*-18* at idle.
    Has anybody experimented with this stuff? Any good advice?
    Arn
    Arn Brown
    Go as much as you can until it pings during driving and then back it off 2*
    Changing to higher octane gas will allow for more and more timing.
      i am running 14 * initial, 38* total with my stock efi motor. i dont get any ping.
      just try throwing some timing at it and play with it some more. if it pings, back it off.
        thanks
        Thanks for the tips guys. I'll be playing around with it some.
        Arn
        Arn Brown
