I was looking at the original Indy beretta engine specs and I seen that it used an aluminum block . So the question is if I ever have to rebuild my 3.1L MPFI engine in my Indy would it be possible to use this aluminum block(if I can order one), and still use the orignal crank,heads and plenum. Reason being is the aluminum block for one is alot lighter and also the fact that it seems you can bore it to 92mm and get 3.4L displacement. Thanks for looking, and sry in advance if this was covered( I looked through the old posts and didn't see anything so).
Edit- Here is the block part number "10051141 Bow Tie Aluminum Block"
