AJ-USA offers a wide selection of performance and OEM automotive parts for your car, truck, suv, motorcycle or watercraft. In business since 1976 you can trust us to provide you with top service and the lowest available prices!
if your gonna spend money on a chip, get a custom one, if you have mods/built motor. it will cost more, but probably better off. one-size-fits-all is ok for stock, pretty much all it does is advance the timing curve so you get a little more power in the lower rpms, probably doesnt help peak hp at all. If you have the cold t-stat, you get away with more timing advance. probably adds fuel to keep it cool too.
for $200 you could make a cai probably get better results.
Ok thanks. I figured there was not too much benefit to getting those. I will be fabbing up a CAI this spring, already have the intake itself. I'm looking into a custom chip, basically I don't want any changes other than the limiter removed. Since I probably won't be beefing up any internals I don't need to change the shift points anyway.
Figure out where your ECM is. Then try to find something that looks even remotely like that picture. I doubt you will. Since you have a W-Body 3100, your ECM is a flash unit, not a PROM unit. IOW, that site is wrong. But like I said, find your ECM and prove me wrong...
