3100 mods
  • #16
    You could always use a 62 mm throttle body that bolts right up and plugs up. you just have to match port the intake. I used the 3400 intake for mine.
    95 Beretta Z-26
    Don't need nitrous to go fast.
    Global peace through deadly force!
    • #17
      $200 for the 62 mm TB vs. $10 for the 65mm TB is what made me start the redesign of Idle air.
      • #18
        the idea that a turbo doesnt draw power to make power is wrong. i think everyone had that discussion about the electric water pump. but then again look up supercharged cars. a roots-type if done right will add more power across the board than its taking. a turbo gets its power fomr the exhaust. and only if the turbo manifold is disgned good enough will it draw as little power as possible (in the form of back pressure). i wouldnt even recommend a centrifugal supercharger for these cars unless its going to be raced. need revs for those or giant, expensive one to not kill low end power.
