Well I got some cash now and soon to have income tax payed back. So I think I will be buying my set of pistons for my proposed turbo'd 3.1/3400. I dont know if I should just save up and learn more, but then I'll likely spend the cash.
Thing is I want to get a high compression turbo charged engine. I want to run 9:1 comp or close as possible. I know curtis runs 8:1, and what I propose to do is likely not the smartest for a starter. The stock C/R is 8.9/1, and if I cant do 9:1 I will most definitely do 8.5:1. Numbers are still in the air, I think I will go to a couple performance shops and see what they have to say before I get this decided.
So questions are, can I acheive this with just piston pin relocation? I assume I can, but could be wrong.
Second, reason for the high comp idea is I plan to do some pretty good air/water intercooling, with a standalone comp like colin bulocks holley comander, so I'm hoping to stray from pre-ignition. Keep in mind this is a long term project, and I do plan to go through with it over the course of several years.
Hoping to start around 10psi and make it up to 15 then work from there. Turbo is yet to be choosen
Opinions please?
Opinions please?
