3400 intake swap walkthrough?
  • 3400 intake swap walkthrough?
    I'm looking to do the 3400 intake swap, and I have a text-based walkthrough on it, but I know there were pictures that went with it, that I'd like to find. If anyone has any pics of this swap, or if there's something I'm missing, please direct me to it, thanks!!
    1995 Pontiac Grand Prix SE - 3100/3400 hybrid
    RE: 3400 intake swap walkthrough?
    Hmm... I have pics somewhere. I just need to find them. Where did you get the write-up and perhaps that will help me locate what pictures you need. I'm guessing you are putting it on the 95 GP? First thing you need to do is check which rockers you have. Since its a 95, they should be the stamped rockers, but some 95s did get rollers. If you have stamped rockers, then the procedure is a little more involved. If you have stamped rockers, check to see if you have the notch below the pushrod guide for the roller rocker pedestal. If so, then you might look for some roller rockers to go along with the swap.
      Well, this is gonna be the first time I've ever torn into an engine, but I need to do the intake gaskets as well, because I think they're going out. I was doing GM top end cleaner, and I watched smoke come from my engine, as well as the exhaust.
      I also need to know what gaskets I'll need. Do I have to fab up any? Should I use RTV on the gaskets?
      Pics of the difference between rockers would help, too. Sorry I'm so worthless here, but I'm learning.
