well, if you were able to put on one of those cam phasers, like the delphi one, then you would need a method to control it. you could have to set up a rate of change, which should be pretty close to changing with rpm. so you would try to as the rpms climb, the cam timing changes.
you probably would want to change your ignition timing maps to go along with this new cam advance or retard. something the GM guys could do, but for the average shadetree mechanic, it would be a tuning nightmare.
