Underdrive Pulley Belt
  • Underdrive Pulley Belt
    Does anyone have a serpentine belt # for 95 3100 engine with the FFP Underdrive Damper.I am just going to install it and FFP said the belt should be about 1 inch shorter than stock with the new pulley on.Just wondering if anybody has match it yet if not i'll just buy a bunch and try them.Unless the Circumference is written on each belt,that would be easier.Thanks guys They wanted to know how i found out about there products so i gave the site a big Hell Ya.
    1995 Cutlass Supreme 3100 SFI
    Cold Air K&N Filter
    58mm TB
    Dynomax Duel Exhaust with Performance Catalytic Converter
    FFP Underdrive Crank Pulley
    1/4 mile 15.65 at 90.8 mph
    The size should be on the stock belt, unless it is worn off. If it isn't readable, just hit your local parts store and ask them to look it up. Generally, the last 3 digits of the belt part number are the size. For example, a xx665 belt would be 66-1/2" long, xx580 would be 58", and so on. You just need to find out the stock number, and get one an inch shorter.
    Marty
    '99 Z-28 - Weekend Driver
    '84 X-11 - Time and Money Pit
    Quote of the week:
    Originally posted by Aaron
      Go to the parts store and ask for a belt that is ONE INCH shorter. Thats all there is to it.
        Man you ever been to a part store and they know what there talking about,most of them can't tie there own shoe wihtout a part number.Hhhehee
        Cold Air K&N Filter
        58mm TB
          Ask for a stock belt. Read the last three numbers on the package. (ex: 715) For ONE INCH shorter, get a belt with the same # as the stock one, except for 705 as the last three #s.
            I work at a good auto parts store and we actually know how a car works. If you have a/c then your stock gatorback belt is 4060710 or 710k6 regular; so you would need 4060700 in gatorback or a 700k6 for a regualr belt.
            -Jay
              NO offence on the auto parts store, but they just don't know anything or maybe care to know anything around were i live but the information is great ill try it out thanks for the help.
              Cold Air K&N Filter
              58mm TB
                060675, is the part number from the belt I got at NAPA when I put my UDP on.
                -1996 Beretta
                3400 SFI / 4T60-E
                -1991 Grand Prix SE
                3.4L DOHC / HM-284
                  Okay i went to the parts store and they have 1/2 shorter or 1-1/2 shorter not exactly 1 inch shorter hmm which one to use.Any suggestions
                  Cold Air K&N Filter
                  58mm TB
                    1.5" shorter is what I would get. The tensioner usually allows for an inch or so of play. (Might be kinda hard to get on though)
