i'm planning to put tegether an individual runner setup for my 3.1, just have a few ?'s. i'm sure are stupid. but thats what ?'s are for.
The base of the project is a '97 3100 topside. heads, etc. i plan on using the 3100 lower intake to mount a custom upper intake that using aluminum tubing will hold a 34mm carb on each end. no the carbs wont be fueled. just acting as TB's. im not skilled enough to make 6 indentical ones.
first ?, how long should the runners be?, i want to keep them longer mostly for the low end, but i think it would look nicer, and fit under a hood also. im counting on the carbs to work as TB's so im still using injectors, no worries about throttle response, or fuel falling out of suspension.
next ?, how is the ecm probably going to respond to this mod? i figured out a way to mount a tps in the throttle linkages. and i was just going to let the iac motor leak some filtered air in the runners past the throttles. but what can i expect to happen first time it starts/tries to start? if it starts at all...
last ?, what kind of tunning would i have to deal with if all else fails? i been lookin at the haltec e6gm but stil think i dont want to pay for one, unless i really have to. i'd rather keep the stock ecm for budget reasons.
