270lb 3.0L
  • 270lb 3.0L
    would a gen III 80mm stroke crank from an lw9, gen III 170 / 487 aluminum heads and a gen I aluminum block 10051141 bolt together?
    Forged Crankshaft For Gm Buick 3.0L Lw9 24507506 80mm stroke
    Milexaun Forged Crankshaft For Gm Buick 3.0l Lw9 24507506 - Buy Forged Cranks crankshaft 24507506 Product on Alibaba.com
    Aluminum V6 Chevy BLOCK 10051141
    3.1 / 3.4 GM 170 / 487 CYLINDER HEADS PONTIAC AZTEK 10MM ROCKER BOLTS
    I can't remember off the top of my head, but I want to say that the newer cranks have larger journals than the aluminum block. So in order to make it work, you'd have to grind down the crank to match the block mains.
      The LZ4 & LZ9 upped the rod journal size from 2.000 to 2.250 to match the 4.3 V6. I think the earliest 2.8's had smaller mains, but I thought that the BowTie block had the later mains.
      Also, did you notice that the crankshaft supplier is looking for orders up to 4000 units/month?
      Current:
      \'87 Fiero GT: 12.86@106 - too dam many valves; ran 12.94 @ 112 on new engine, then broke a CV joint
      \'88 Fiero Formula: slow and attention getting; LZ8 followed by LLT power forthcoming
      \'88 BMW 325iX: The penultimate driving machine awaiting a heart transplant
      Gone, mostly forgotten:
      \'90 Pontiac 6000 SE AWD: slow but invisible
