Im running a boosted 3.1 , big turbo setup, what is the actual ft/lb of a torque TTY bolt ? Manuals say 44 ft/lb + 90 degree rotation , I Havn't worked on the car in a few years but im back on the game now , I remember in the past torqueing the heads down a bit more to accommodate the higher boost/ bigger turbo. Machine shop estimates 44ft/lb + 90 degree will give you about 65-70 ft lbs of actual torque. Does this sound about right? My other buddy who knows a ton about these motors guessed about 100ft/lbs or more after the 90 degree turn is made . I used to have a magic number for final torque sequence but its been years and I can't remember I was to say 75 or 77 total ??? What do you boosted guys do ?
Also to pick a bone , on a 3.1 the front corner head bolt has a threaded head on top for the Torx bolt , anyone notice the felpro head bolt kit doesn't have this anymore ?? they're all the same long and short that's it .
How the heck would anyone run ARP studs on this motor without leaving that torx bolt out ?? I wouldn't want to do that.
