When are the Multec2 3400 injectors maxed out?
  • When are the Multec2 3400 injectors maxed out?
    I did a search and couldn't find anything in the first 10 pages...but some of you may know this from memory.
    At what point are the 22lb Multec2 3400 injectors insufficient? I've got a 3400 with the Stage 2 heads & intakes with the street/strip cam, running the 3400 regulator (I think it's 55lb).
    I do have an old set of 36lb Multec1s that I can run with the 3100 regulator if needed, but I'd think they are probably overkill and I'd have to make a new harness.
    Thanks
    91 SS . 3400/5spd - S&S, TCE, EP, FFP, SPEC, DSS, K&N . GEARHEAD dezign
    Stockers should provide enough fuel I think but they will prob be maxed if you are making 220+ hp which you should be
    36 seem like overkill. 28 would work good if you can find a bolt in
      You will need to get your hands on some Trailblazer injectors, they are 28#'s
      14.96@91.47 in the 1/4
      9.63@74.36 in the 1/8th
