7000+ RPM requirements
  • #31
    is it even good for pushrod motor to spin over 6k? theres alot of possibility for instability to do its thing isnt there?
    • #32
      No its not a problem. But you do need the right parts.
      • #33
        Okay, I'm on the garage computer right now and the heads are on the bench beside me. The part number is 10048651 on both heads. The upper intake is a 10100017 and says "3.1MultiPortFI".
        So if I put FWD 3.1L pistons on a RWD 3.1L head I'll be okay, right? Worst case I'll just put the 2.8 iron heads back on, or will that even work?
        89 RS - 3.25L V6
        89 RS - 5.7L LT1
        87 S10 - 2.8 flatbed, RS wheels
        • #34
          3.1l aluminum head pistons and ironhead will end up with something like 7.5:1 compression. now if you use aluminum heads with 3.1l ironhead pistons you will get the high compression.
          • #35
            Okay, then I should be good as along as I use the aluminum heads. Too bad I have the wrong heads. According to GM, I need part number 10048649, not 10048651. Do you guys know the difference between the two aluminum heads? If its just the port size I have no problem porting these heads myself.
            89 RS - 3.25L V6
            89 RS - 5.7L LT1
            • #36
              im not fmiliar with numbers but after 94, maybr 95 they motors looked different, 3100sfi or even the 3400sfi, those have the best heads. the mpfi and sfi intakes arent interchangable.
              • #37
                Hopefully its just the porting that they did on those intakes and not the valves. I think I'm going to go ahead and start working on the heads that I have. I'll order up a gasket kit and start the port/polish process. I should be done with them by the time the machinist is done with the block. WOOHAA! I'll update this post with progress pictures as soon as I get them.
                89 RS - 3.25L V6
                89 RS - 5.7L LT1
                • #38
                  8649 and 8651 should be the same head. I've noticed that on 3x00 heads, the head I had in my hands and the GM part number were like 2 or 3 numbers off (ie, the 49 and 51), yet they were the same. I usually go by if its within about 5 of each other then they are the same.
                  • #39
                    awesome. That makes me feel alot better. Now I just have to figure out how to do the intake setup and its a done deal. I fully intend to make public all of the stuff I found out to make this project work. I found descriptions of the head at http://www.sallee-chevrolet.com/Cyli...eads/4-6V.html , but it doesn't list the head that I have at home. So your information helps me out alot. Does anyone know if they ever made a RWD intake for these heads? I know that the 3.4L camaro's use the same lower intake as the iron head 2.8's but have a different upper intake. I haven't been able to find any site that lists this head for a RWD application. I believe the intake will be my biggest hurdle at this point.
                    89 RS - 3.25L V6
                    89 RS - 5.7L LT1
                    • #40
                      i think aluminum heads are fwd exclusive. maybe you can get away with the 3x00 bottom intake and custom make that twinn throtlebody setup you mentioned before.
                      • #41
                        No there is no RWD intake for aluminum heads. But just turn the whole thing around.
                        I thoughy you were going to go with a 2.8L crank for this 7000RPM build are you not? If you are, you CANNOT use 3.1L pistons of any type.
                        • #42
                          In case anyone would be interested; I am not really on the marklet to sell any of my goods but, I am broke so..
                          I have a set of Federal Mogul H562CP (+1.00MM) Pistons. Which are designed for 3.1 Iron Heads and have coated skirts, of course. but, when used with Alum heads they have very pleasing high compression levels. I will sell them very cheap.
                          I also have a set of 8 Pre-68 Small Journal V8 Connecting rods. Which, as we all know, can be machined to fit a 660 Motor nicely. these rods have been reconditioned and balanced but, are not cut and bushed for the 660 motor. you would need to have them machined.
                          I also have a set of reconditioned 3100 heads that are from pre-00 years. And, if you're in the market for Gen II parts, which noone is, I have an arsenal which I will sell parts from at extremely low prices as, they aren't worth anything to me really.
                          Sorry to post like this but, I figured it could be useful to someone.
                          "...you CANNOT use 3.1L pistons... " I have heard this type of speak before but, wouldn't it be possible to use a GenII/III high compression 3.1 piston on a GenII/III 2.8 Crank to achieve low compression? Or would that just cause a horrible flame travel situation?
                          -Dave
                          If I seem Crazy it is because, I am insane. No lie. Ask my psychiatrist. But, i have good intentions. sometimes.
                          • #43
                            LOW is right. I dont even know how low it would be.
