Long story short.....I spun the crank in my 2.8L 89 Camaro. After seriously contemplating putting in a 350, I've decided to stay V6. So now I'm back on track on building up my little NA 2.8L. (no turbo/nos.....yet)
Goal -> Since GM says everything stock will support 7000RPM, thats what I'm going for. I want to rev it that high AT LEAST!
What I have -> a nice 2.8L block, cleaned, and tested straight. FWD 3.1L alum heads/intake, 2.8L iron heads, 3.1L rotating assy.
I ordered up the GM Power book from my local chevy dealer, so I have tons of idea's and methods, but I need help solidifying on a final goal. 7000 shouldn't be that hard to reach, granted everything is balanced, all oil lines are ported, de-burred, and enlarged where needed. But what should I do with the top end? Should I try to put the aluminum heads on, or should I stay with the irons? I know that the 3.1 heads flow better, but the intakes for the heads are far worse. Headers are a must, and I intend on ordering up the CompuCam. But even then, that cam is sudo-rated between 1500-4500. Will I kill myself if I try to push it that hard? or is it really an approximation?
So my main concern is this:
If the rotating assembly (cam, crank, rods, pistons) will handle the REV's of 7000-10000 RPM's, what would be the best head/intake setup to support onwards of 500cfm of air?
