rocker arms
  • rocker arms
    I am building a 3.4 for my suv, what are good rocker arms to use? I really dont want to keep stock.
    RE: rocker arms
    Which 3.4 are you using? RWD iron head or FWD aluminum? I believe the Crane gold race rockers will bolt on either one, or you can do like I did and use SBC roller rockers, but you have to get the ARP rocker studs with the 10mm bottom thread and 3/8" top thread. Also, the SBC rockers may need to be checked for clearances with the intake manifold, and valve covers.
    Franz
    1990 Z24-NA 3.1L
    14.72 @ 92.24 MPH
    14.89 @ 94.92 MPH
    The boost is coming....
      RE: rocker arms
      ^ quite a few rocker arms for the iron heads
      3.4L camaro some goodies
        The Cranes are the top of the line. I use them and love them. They are pricey though.
          if you want a bigger ratio for cheap you can even go with '93-'95 3100 rockers. they are 1.6 ratio.
          Lorenzo
            Um 93-95 rockers on 3100's are 1.5 ratio are they not?
              Yes they are.
              Colin
                No, they are 1.6 ratio. I got that info direct from GM Powertrain. I always thought that they were 1.5 as well, but my guy at GM confirmed that they are in fact 1.6.
                  If thats the case, I have some sitting here at my place, for dirt cheap.
                  1992 Miata B Package
                  1995 Regal 3100
                  1996 Firebird LT1 T56
                    Slick, sent you a PM about the rockers.
                    1990 Grand Prix STE Turbo
                      Got it.
                      1995 Regal 3100
                        Really? Hmm.. interesting.
                        Colin
                          yeah the are 1.6. My '93 3100 manual says plus you can compare the pushrod seats with th eolder ones. definalty 1.6.
                          Lorenzo
                            Sorry if this has been addressed before but would it be possible to use the 93-95 3100 1.6 rockers in a GEN II motor? If so, would new pushrods be needed as well?
                            Thanks!
                            -- Scott
                              Yup just plop them in.I gurentee you'll feel somthing from it. Also if you cant swing getting a chip, Get fuel injectors from a 3300 V6. I gurentee those two togther will make the engine happier.
                              Lorenzo
